disable vpls service
disable vpls [vpls_name | all] service
This command has been replaced with the following command: disable l2vpn [vpls [vpls_name | all] | vpws [vpws_name | all]] service .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Description
Disables the configured VPLS services for the specified vpls_name.
Syntax Description
vpls_name Identifies the VPLS within the switch (character string).
all Specifies all VPLS.
Default
Enabled.
Usage Guidelines
When services are disabled, the VPLS is removed from all peer sessions. The keyword all disables services for all VPLS instances.
The following command disables the configured VPLS services for the specified VPLS:
disable vpls myvpls service
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
